Ana içeriğe geç
Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement
Neye ihtiyacın var
  1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, J1 Screws on Throttle: adım 1, 1 resimden 1.
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: adım 2, 2 resimden 1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: adım 2, 2 resimden 2.
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: adım 3, 2 resimden 1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: adım 3, 2 resimden 2.
    • Remove the four 13 mm J1 JIS head screws from the rudder assembly holder.
  4. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: adım 4, 1 resimden 1.
    • Gently remove the panel that is covering the rudder.
  5. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: adım 5, 1 resimden 1.
    • Proceed to remove the rudder from the throttle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Julissa Orozco
351 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G1
3 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
¿Haceraptencomr?
Alfredo Sanchez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,848
