Ana içeriğe geç
Thrustmaster T Flight Hotas 4 Trigger Replacement
Neye ihtiyacın var
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: adım 1, 2 resimden 1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: adım 1, 2 resimden 2.
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: adım 2, 3 resimden 1. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: adım 2, 3 resimden 2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: adım 2, 3 resimden 3.
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: adım 3, 1 resimden 1.
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: adım 4, 3 resimden 1. Thrustmaster T Flight Hotas 4 Trigger Replacement: adım 4, 3 resimden 2. Thrustmaster T Flight Hotas 4 Trigger Replacement: adım 4, 3 resimden 3.
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
Sonuç
Aaron Banaga
526 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G1
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 3,390
