Giriş
Use this guide to replace broken gas or break pedal.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
I am also looking for this spring. Any help would be appreciated.
thanks
