Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
Remove the 10mm long black screws on the back of the base using a PH2 Phillips head screw driver. There are 13 screws total.
Gently lift cover out to access inside.
Push the pin that holds the pedal out from middle outward.
Install the new pedal with springs and pin and make sure that the pin holds them together.
Add a little grease on pin when installing the new pedal.
Repeat steps in reverse to reassemble device.
2 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
I am also looking for this spring. Any help would be appreciated.
thanks
Me too. Are these springs available?
I only need 1 spring, not 10....
Anyone selling 1 spring?
