Giriş
Use this guide will show how to replace the USB cable.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Neye ihtiyacın var
Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
3 farklı kişi bu kılavuzu tamamladı.
7 Yorum
kunt u mij vertellen waar ik het kabeltje kan kopen?
Rene
Can you advise on where to obtain a new usb cable please? (clentonmalcolm@gmail.com)
Have you solved it? I'm worried it's different from the regular usb line.
sunned -
Then wat where do u get usb cord to replace it some one plz explian
Oh man.. the first comment about this was 2019 and we both are still waiting for an answer huh
Where can I find a replacement USB cable for the Thrustmaster 458?? The one that goes from the xbox to the thrustmaster controller. Thank you.
About the usb cable. Look for a "5 pin Xbox 360 usb cable". The black pin farthest from the soldered wire is a shield ground wire. Just splice that right most black wire with the soldered black wire to ground the board and cable. These 2 black wires on the board are the furthest points away from each other. I found this out by carefully trimming the sheath from around the wires and sliding the shielding towards the remaining cable
