Ana içeriğe geç
TiVo Premiere XL4 Motherboard Replacement
Neye ihtiyacın var
  1. TiVo Premiere XL4 Motherboard Replacement, Case: adım 1, 1 resimden 1.
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Motherboard Replacement: adım 2, 2 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Motherboard Replacement: adım 3, 1 resimden 1.
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. TiVo Premiere XL4 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the single 140 mm T8 screw from the back panel using a Torx screwdriver.
  5. TiVo Premiere XL4 Motherboard Replacement: adım 5, 2 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 5, 2 resimden 2.
    • Unplug the wire of the fan by gently squeezing the connector and lifting up.
  6. TiVo Premiere XL4 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the power supply wire by pinching the plastic connection and gently pulling away from the motherboard.
  7. TiVo Premiere XL4 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the single 80 mm T10 screw above HDMI port using the Torx screwdriver.
  8. TiVo Premiere XL4 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove wire connected to the front of of the box by pinching the connector and gently removing from the motherboard.
  9. TiVo Premiere XL4 Motherboard Replacement: adım 9, 2 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove two 100 mm T10 screws connecting the front cover to the hardware of the box using a Torx screwdriver.
    • Unplug the connector from the front panel.
  10. TiVo Premiere XL4 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the front of the TiVo.
    • This step helps with the process of removing the motherboard due to the plastic prongs putting pressure on the board.
  11. TiVo Premiere XL4 Motherboard Replacement: adım 11, 1 resimden 1.
    • Using pliers, be sure that the cable jack is centered with the back of the box for easy removal.
    • This step above is only necessary if it is not aligned.
    • Remove the nut on the cable jack using pliers.
    • Remove the washer after removing the nut.
  12. TiVo Premiere XL4 Motherboard Replacement: adım 12, 3 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 12, 3 resimden 2. TiVo Premiere XL4 Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the following (2) 80 mm T10 screws including the (2) 80 mm T10 screws located on the other side using the Torx Screwdriver.
    • Remove hard drive from on top of the motherboard.
  13. TiVo Premiere XL4 Motherboard Replacement: adım 13, 3 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 13, 3 resimden 2. TiVo Premiere XL4 Motherboard Replacement: adım 13, 3 resimden 3.
    • Pinch the connector of the bundle of wires (the bundle having black, red, black and yellow wires) and gently remove from the motherboard.
    • Pinch the connector of the single flat red wire and gently remove from motherboard.
  14. TiVo Premiere XL4 Motherboard Replacement: adım 14, 2 resimden 1. TiVo Premiere XL4 Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the two 200 mm screws holding the motherboard in place to the bottom of the box using pliers.
  15. TiVo Premiere XL4 Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the six 80 mm T10 screws using the Torx Screwdriver.
  16. TiVo Premiere XL4 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the motherboard from the box.
Sonuç
Frances Prewitt
661 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G1, Williams Fall 2018 Baylor, Team S1-G1, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G1
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 575
