Giriş
The power supply keeps the TiVo fully functioning with power. if some component is bent or needs replacement then the supply may need to be fixed; here is how to replace the power supply.
Neye ihtiyacın var
Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
Remove the 140 mm T8 screw from the back of the TiVo premiere XL4 box holding the power supply in place using a Torx screwdriver.
Bir başkası bu kılavuzu tamamladı.
