Ana içeriğe geç
TiVo Series 2 TCD24008A Hard Drive Replacement
Neye ihtiyacın var
  1. TiVo Series 2 TCD24008A Hard Drive Replacement, Cover: adım 1, 1 resimden 1.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 3, 1 resimden 1.
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Locate the hard drive.
  5. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 5, 2 resimden 1. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  6. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 6, 3 resimden 1. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 6, 3 resimden 2. TiVo Series 2 TCD24008A Hard Drive Replacement: adım 6, 3 resimden 3.
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
Sonuç
Talha
31 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G33
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 1,736
