Ana içeriğe geç
TiVo Series 2 TCD540080 Motherboard Replacement
Neye ihtiyacın var
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: adım 1, 1 resimden 1.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: adım 3, 2 resimden 1. TiVo Series 2 TCD540080 Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: adım 9, 1 resimden 1.
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: adım 10, 3 resimden 1. TiVo Series 2 TCD540080 Motherboard Replacement: adım 10, 3 resimden 2. TiVo Series 2 TCD540080 Motherboard Replacement: adım 10, 3 resimden 3.
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: adım 11, 1 resimden 1.
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Svyatoslav Markeyev
135 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G79
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 4,496
