Ana içeriğe geç
TiVo Series 2 TCD540080 Power Supply Replacement
Neye ihtiyacın var
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: adım 1, 1 resimden 1.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: adım 2, 1 resimden 1.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: adım 3, 2 resimden 1. TiVo Series 2 TCD540080 Power Supply Replacement: adım 3, 2 resimden 2.
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: adım 4, 2 resimden 1. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: adım 4, 2 resimden 2.
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: adım 5, 1 resimden 1.
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: adım 6, 1 resimden 1.
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: adım 7, 2 resimden 1. TiVo Series 2 TCD540080 Power Supply Replacement: adım 7, 2 resimden 2.
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: adım 8, 2 resimden 1. TiVo Series 2 TCD540080 Power Supply Replacement: adım 8, 2 resimden 2.
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Svyatoslav Markeyev
135 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S33G79
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 5,171
