Ana içeriğe geç
Timbuk2 Suitcase Roller Handle Replacement
Neye ihtiyacın var
  1. Timbuk2 Suitcase Roller Handle Replacement, Roller Handle: adım 1, 1 resimden 1.
    • Here are the tools you will need:
    • New roller handle set
    • Screwdriver
    • 4mm Allen wrench
  2. Timbuk2 Suitcase Roller Handle Replacement: adım 2, 1 resimden 1.
    • Open luggage and unzip backing, exposing back of roller. Using an Allen wrench, unscrew all 10 screws along the bottom plate and remove plastic coverings
  3. Timbuk2 Suitcase Roller Handle Replacement: adım 3, 1 resimden 1.
    • Turn luggage over and using Allen wrench, unscrew all 8 bolts on the back of luggage handle assembly. Remove handle frame from luggage body
    • Put the new roller handle set in place. Repeat steps 2 and 3 in the opposite order.
    • You're finished!
Bitiş Çizgisi
Emilee
1.591 İtibar
9 adet Kılavuz yazıldı
3 Yorum
Excuse me, but there's nothing in these instructions about removing the wheels from the old assembly and installing them on the new one? Can someone please supply those instructions so that I can complete this assembly? Thanks much!
robin - Yanıt
Agree, I also found this step missing. It should be “step 3.5”. Moving the wheels to the new handle is where the screw driver comes in. After the handle is detached from the case, there are two small philips head screws that must be removed, one next to each wheel. After the screws are out, the wheels pull out from the tube of the old handle, and can be moved to the new handle. After pushing the wheels back into the new handle, align the tab of the plastic wheels into the indentation on the tube of the handle. Once aligned, the screw hole should be visible. Put the screws back in and you’re ready for step 4, reconnecting the handle to the bag.
stevenfry - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 4,527
