Ana içeriğe geç
Timex T132 "iMac" Alarm Clock Battery Replacement
Neye ihtiyacın var
  1. Timex T132 "iMac" Alarm Clock Battery Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent any injury, unplug the power cord from the outlet so the device is powered off.
    • Hold the clock so it is upside down. You should be able to view its caution labels.
    • Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
    • Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
  2. Timex T132 "iMac" Alarm Clock Battery Replacement: adım 2, 3 resimden 1. Timex T132 "iMac" Alarm Clock Battery Replacement: adım 2, 3 resimden 2. Timex T132 "iMac" Alarm Clock Battery Replacement: adım 2, 3 resimden 3.
    • Rotate the device so the clock's display is facing away from you.
    • Use the flat end of the spudger to pry out the battery.
    • Once fully lifted, grab the end of the battery and pull out the rest of the battery.
    • Do not remove the battery all the way because it is still connected. Doing so may result in damaging the power wires.
  3. Timex T132 "iMac" Alarm Clock Battery Replacement: adım 3, 1 resimden 1.
    • Place the clock upside down on a flat surface.
    • Because the device is irregularly shaped, you may have to manually or externally balance it.
    • Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
    • Do not pull out the snap connector and its wires because it is still connected to the device. Doing so may result in damaging the power wires.
    • Remove the battery.
Sonuç
Tyler Price
1.038 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G2
5 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 310
