Ana içeriğe geç
Timex W-10 Children's Watch Battery Replacement
Neye ihtiyacın var
  1. Timex W-10 Children's Watch Battery Replacement, Battery: adım 1, 3 resimden 1. Timex W-10 Children's Watch Battery Replacement, Battery: adım 1, 3 resimden 2. Timex W-10 Children's Watch Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Pull on the watch strap through the top of the strap buckle to unlock the strap.
  2. Timex W-10 Children's Watch Battery Replacement: adım 2, 2 resimden 1. Timex W-10 Children's Watch Battery Replacement: adım 2, 2 resimden 2.
    • Once the strap has been unlocked, hold onto the strap buckle and pull away from the watch to completely remove the band.
  3. Timex W-10 Children's Watch Battery Replacement: adım 3, 2 resimden 1. Timex W-10 Children's Watch Battery Replacement: adım 3, 2 resimden 2.
    • Use the PH00 screwdriver to remove the four screws from each corner of the rear metal cover.
  4. Timex W-10 Children's Watch Battery Replacement: adım 4, 2 resimden 1. Timex W-10 Children's Watch Battery Replacement: adım 4, 2 resimden 2.
    • Gently remove the back plate to expose the battery.
  5. Timex W-10 Children's Watch Battery Replacement: adım 5, 2 resimden 1. Timex W-10 Children's Watch Battery Replacement: adım 5, 2 resimden 2.
    • The battery spring will propel the battery upward as soon as the base cover is removed. Be sure to place the battery in a safe spot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
I'm looking for an adult Timex watch battery replacement that has a metal watch band.
Daniel Melendrez - Yanıt
Daniel Melendrez - June 12
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 8,189
