Ana içeriğe geç
Tineco FLOOR ONE S3 Breeze Motherboard Replacement
Neye ihtiyacın var
  1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: adım 1, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove six 10.6 mm screws from the back of the vacuum with a Phillips #1 screwdriver.
    • Remove the entire back piece.
  2. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove four 10.6 mm screws from the remaining white back piece with a Phillips #1 screwdriver.
  3. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 3, 3 resimden 1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 3, 3 resimden 2. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 3, 3 resimden 3.
    • Pry open and remove the black ring at the top of the vacuum using by using an opening tool.
    • Remove four 10.6 mm screws located underneath the previously pried ring using a Phillips #1 screwdriver.
    • Remove the top circular piece from the body of the vacuum.
  4. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the white back piece of the vacuum.
  5. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 5, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 5, 2 resimden 2.
    • Unplug the wires of the battery by carefully pulling them up from the motherboard.
    • Slide the battery out of its slot and replace it with the new battery.
    • The connection may be difficult to remove. Be careful not to rip the entire connector from the motherboard.
  6. Tineco FLOOR ONE S3 Breeze Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Carefully remove all the wire connections from the motherboard.
    • Take note of where and how the wires were connected, so they can be rewired to the new motherboard.
  7. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 7, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the four 10.6 mm screws holding the motherboard using a Phillips #1 screwdriver.
    • Carefully remove the motherboard from the vacuum.
Sonuç
Dawoud Daoud
199 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 150
Her zaman: 714
