Ana içeriğe geç
Tineco FLOOR ONE S3 Breeze Motor Replacement
Neye ihtiyacın var
  1. Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: adım 1, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motor Replacement, Wheels: adım 1, 2 resimden 2.
    • Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
    • Remove the first plastic cover.
  2. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 2, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 2, 2 resimden 2.
    • Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
    • Remove the second plastic cover.
  3. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 3, 2 resimden 1. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 3, 2 resimden 2.
    • Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
    • Remove the wheels.
    • The wheels do not need to be removed to access the motor.
  4. Tineco FLOOR ONE S3 Breeze Motor Replacement, Motor: adım 4, 1 resimden 1.
    • Remove the motor and the brush arm.
  5. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 5, 1 resimden 1.
    • Remove three 10.56 mm screws from the gear with a Phillips #1 screwdriver.
  6. Tineco FLOOR ONE S3 Breeze Motor Replacement: adım 6, 1 resimden 1.
    • Simply pull by the base of wires to remove them from the motor.
    • Remove the gear from the brush arm.
Sonuç
Luke Guess
196 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 32
Son 30 gün: 122
Her zaman: 1,032
