Ana içeriğe geç
Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement
Neye ihtiyacın var
  1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: adım 1, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: adım 2, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: adım 2, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the valve handle: adım 2, 3 resimden 3.
    • Use a flat punch tool and a hammer to tap the groove pin from left to right out of the valve handle.
  3. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: adım 3, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the valve handle from the cam base.
    • During reassembly, apply grease to the cam base before reattaching the valve handle.
  4. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: adım 4, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: adım 4, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the cam base: adım 4, 3 resimden 3.
    • Remove the cam base.
  5. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: adım 5, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Loosen the bypass valve assembly: adım 5, 2 resimden 2.
    • Use a 13/16" wrench, or an adjustable wrench, to loosen the bypass valve assembly.
    • Rotate the wrench counterclockwise.
  6. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: adım 6, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Bypass Valve Assembly Replacement, Remove the bypass valve assembly: adım 6, 2 resimden 2.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
163.918 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 747
