Ana içeriğe geç
Titan Airless Sprayer IMPACT 410 Packings Replacement
Neye ihtiyacın var
  1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Safety precautions: adım 1, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Unfasten the front cover: adım 2, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Unfasten the front cover: adım 2, 2 resimden 2.
    • Use a Phillips driver to remove the four 15 mm-long screws securing the front cover.
  3. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the front cover: adım 3, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the front cover: adım 3, 2 resimden 2.
    • Remove the front cover.
  4. Titan Airless Sprayer IMPACT 410 Packings Replacement, Reposition the pump: adım 4, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Reposition the pump: adım 4, 2 resimden 2.
    • Plug in the power cord.
    • Pulse the on/off switch until the pump stops at the bottom of its stroke.
    • Turn the sprayer off and unplug its power cord before continuing.
  5. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the return hose: adım 5, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the return hose: adım 5, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the return hose: adım 5, 3 resimden 3.
    • Pinch the return hose clamp and slide it downward to expose the connector.
  6. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 6, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 6, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 6, 3 resimden 3.
    • Use your fingers to remove the retaining clip from the foot valve housing.
  7. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 7, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 7, 2 resimden 2.
    • Use a 7/16" wrench to unscrew the return hose.
  8. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 8, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 8, 2 resimden 2.
    • Remove the return hose.
  9. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the foot valve housing: adım 9, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the foot valve housing: adım 9, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the foot valve housing: adım 9, 3 resimden 3.
    • Use an adjustable wrench to loosen and remove the foot valve housing.
  10. Titan Airless Sprayer IMPACT 410 Packings Replacement, Loosen the inlet valve housing: adım 10, 1 resimden 1.
    • Lay the sprayer down horizontally on its black metal bars before continuing.
    • Use an adjustable wrench to loosen the inlet valve housing from the pump block.
  11. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the inlet valve housing: adım 11, 1 resimden 1.
    • Remove the inlet valve housing.
  12. Titan Airless Sprayer IMPACT 410 Packings Replacement, Inlet valve information: adım 12, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Inlet valve information: adım 12, 2 resimden 2.
    • If you're replacing the inlet valve, note the installation order from first to last (Teflon O-ring first and Piston Bushing last):
    • Teflon O-ring
    • Inlet valve seat
    • Inlet valve ball
    • Inlet valve washer
    • Nylon washer
    • Piston bushing
  13. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the outlet valve retainer: adım 13, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the outlet valve retainer: adım 13, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the outlet valve retainer: adım 13, 3 resimden 3.
    • Use a 5/16 inch hex key to loosen and remove the outlet valve retainer.
  14. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 14, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 14, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 14, 3 resimden 3.
    • Use a pick tool to remove the outlet valve seat.
    • Remove the outlet valve ball.
  15. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 15, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 15, 2 resimden 2.
    • Remove the O-ring.
    • Remove the outlet valve cage.
  16. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the pump block: adım 16, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the pump block: adım 16, 2 resimden 2.
    • Use a 3/8 inch hex key to loosen and remove the two screws securing the pump block.
  17. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 17, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 17, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement: adım 17, 3 resimden 3.
    • Pull the pump block away from the sprayer to separate it from the pump housing.
    • Pull the pump block upward to slide the piston rod out of its slot in the pump housing.
    • Remove the pump housing.
  18. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston: adım 18, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston: adım 18, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston: adım 18, 3 resimden 3.
    • Use your palm to push the piston through the pump block.
    • This may require a significant amount of force.
    • Remove the piston.
    • During reassembly, grease the piston before reinserting it into the pump block.
  19. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the retainer nut: adım 19, 2 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the retainer nut: adım 19, 2 resimden 2.
    • Use an adjustable wrench to loosen and remove the retainer nut.
  20. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston guide: adım 20, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston guide: adım 20, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the piston guide: adım 20, 3 resimden 3.
    • Remove the the piston guide from the retainer nut.
  21. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the packings: adım 21, 3 resimden 1. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the packings: adım 21, 3 resimden 2. Titan Airless Sprayer IMPACT 410 Packings Replacement, Remove the packings: adım 21, 3 resimden 3.
    • Use a punch tool and a hammer to remove the upper packing assembly.
    • Repeat the same procedure for the lower packing assembly.
    • During reassembly, use the included packing guide tool to reinstall the assemblies. The packings will begin to shrink once removed from the guide, so reassemble the piston immediately.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
163.918 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 1,809
