Giriş
Use this guide to replace the inlet valve in the Titan Elite 3000 High Pressure Airless Sprayer.
Neye ihtiyacın var
Turn off and unplug the sprayer.
Lay the sprayer down horizontally before continuing.
Use the included 30 mm wrench, or any 30 mm wrench, to loosen the inlet valve housing.
Use a flathead screwdriver to pry and remove the clip securing the inlet valve.
Use your fingers to pull up and remove the inlet valve from the bottom of its housing.
2 farklı kişi bu kılavuzu tamamladı.
