Giriş
Removing the speaker will require back plate removal and battery removal, both of which have replacement guides for. The speaker is easily located within the device and requires minimal tools.
Parçalar
Hiçbir parça belirtilmedi.
With the device face down, slide the charging port cover off on the left side of device.
The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
With the face of the device down, the speaker will be in the upper right corner. The black oval shaped object.
The speaker will be connected to two wires; one black and one red. Both run to the motherboard.
The wires will need to be soldered off the motherboard.
Locate where both wires are soldered to the motherboard.
Review How to Solder Here
