Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show the proper way to remove the USB charging port from the device, so that a new one can replace it.
Neye ihtiyacın var
With the device face down, slide the charging port cover off on the left side of device.
The battery rests flat on the inside surface of the tablet. It is a rectangular shape and has blue and yellow tape.
With the device facing down, the USB charging port can be located on the left side of the device directly on the motherboard. The mini HDMI port will be above the charging port and the micro SD port will be below, with the charging port in the middle of the two.
The charging port will be soldered down at all four corners; each prong will need to be soldered off.
Review How to Solder Here
2 farklı kişi bu kılavuzu tamamladı.
