Ana içeriğe geç
Toast Master Blender Button Replacement
Neye ihtiyacın var
    1. Toast Master Blender Button Replacement, Blender Button: adım 1, 3 resimden 1. Toast Master Blender Button Replacement, Blender Button: adım 1, 3 resimden 2. Toast Master Blender Button Replacement, Blender Button: adım 1, 3 resimden 3.
      • Unplug the plug if connected to any outlets.
      • Take off the cap from the blender and turn the appliance upside down.
      • The blender should be standing upward stably.
      FixBot'a Sor
      Yorum Ekle
    2. Toast Master Blender Button Replacement: adım 2, 3 resimden 1. Toast Master Blender Button Replacement: adım 2, 3 resimden 2. Toast Master Blender Button Replacement: adım 2, 3 resimden 3.
      • Use an allen wrench to remove the three screws from the bottom cover.
      FixBot'a Sor
      Yorum Ekle
    3. Toast Master Blender Button Replacement: adım 3, 3 resimden 1. Toast Master Blender Button Replacement: adım 3, 3 resimden 2. Toast Master Blender Button Replacement: adım 3, 3 resimden 3.
      • Take off the black blender stand.
      • Take off three silver screws.
      • Put the screws safely aside.
      FixBot'a Sor
      Yorum Ekle
    4. Toast Master Blender Button Replacement: adım 4, 3 resimden 1. Toast Master Blender Button Replacement: adım 4, 3 resimden 2. Toast Master Blender Button Replacement: adım 4, 3 resimden 3.
      • Use the Allen wrench to remove the three silver screws on the next level of the blender.
      FixBot'a Sor
      Yorum Ekle
    5. Toast Master Blender Button Replacement: adım 5, 2 resimden 1. Toast Master Blender Button Replacement: adım 5, 2 resimden 2.
      • Remove the black cap by lifting it upwards and gently placing it aside.
      • Do not pull hard on the wire as this may cause it to break
      FixBot'a Sor
      Yorum Ekle
    6. Toast Master Blender Button Replacement: adım 6, 3 resimden 1. Toast Master Blender Button Replacement: adım 6, 3 resimden 2. Toast Master Blender Button Replacement: adım 6, 3 resimden 3.
      • Looking into the internal part of the blender, identify the two silver screws near the button and unscrew them with the screwdriver.
      • Carefully remove two silver screws.
      FixBot'a Sor
      Yorum Ekle
    7. Toast Master Blender Button Replacement: adım 7, 3 resimden 1. Toast Master Blender Button Replacement: adım 7, 3 resimden 2. Toast Master Blender Button Replacement: adım 7, 3 resimden 3.
      • Take out the black piece that was attached with the screws and safely place it aside.
      FixBot'a Sor
      Yorum Ekle
    8. Toast Master Blender Button Replacement: adım 8, 3 resimden 1. Toast Master Blender Button Replacement: adım 8, 3 resimden 2. Toast Master Blender Button Replacement: adım 8, 3 resimden 3.
      • Take out the button from the blender.
      • This is the plastic button for Toast Master Blender. If you have a spare button, you can replace it.
      • Make sure that side is facing up and place it back into the original position.
      • The button should have a pointier side that resembles a bunny’s head.
      FixBot'a Sor
      Yorum Ekle
    9. Toast Master Blender Button Replacement: adım 9, 1 resimden 1.
      • Press the button and make sure it has a “click” sound.
      • If the button is still loose, go back to the previous step and recheck that the button is in the correct position.
      FixBot'a Sor
      Yorum Ekle
    10. Toast Master Blender Button Replacement: adım 10, 3 resimden 1. Toast Master Blender Button Replacement: adım 10, 3 resimden 2. Toast Master Blender Button Replacement: adım 10, 3 resimden 3.
      • Reassemble all the parts back, and screw all the screws back to its original place.
      • All the silver screws are the same size.
      • Make sure the black cap separates rotating paddles and wires.
      • There should be no wires wrapped around the rotating blades.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica Li
181 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-8, Andersen Winter 2024 UC Davis, Team 4-8, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S4G8
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 54
Her zaman: 1,222
