Ana içeriğe geç
Toaster Oven Toasting Knob Replacement
Neye ihtiyacın var
  1. Toaster Oven Toasting Knob Replacement, Toasting knob: adım 1, 3 resimden 1. Toaster Oven Toasting Knob Replacement, Toasting knob: adım 1, 3 resimden 2. Toaster Oven Toasting Knob Replacement, Toasting knob: adım 1, 3 resimden 3.
    • Remove the two 4mm by 8mm screws from the back of the toaster oven.
  2. Toaster Oven Toasting Knob Replacement: adım 2, 3 resimden 1. Toaster Oven Toasting Knob Replacement: adım 2, 3 resimden 2. Toaster Oven Toasting Knob Replacement: adım 2, 3 resimden 3.
    • Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
    • Take the two supports off of the bottom.
  3. Toaster Oven Toasting Knob Replacement: adım 3, 2 resimden 1. Toaster Oven Toasting Knob Replacement: adım 3, 2 resimden 2.
    • Remove the two 4mm by 4mm screws from the base in order to remove the tray.
  4. Toaster Oven Toasting Knob Replacement: adım 4, 1 resimden 1.
    • Slide the back panel off of the oven.
  5. Toaster Oven Toasting Knob Replacement: adım 5, 1 resimden 1.
    • Grip the sides of the metal cover and lift the cover up off the toaster oven top.
  6. Toaster Oven Toasting Knob Replacement: adım 6, 3 resimden 1. Toaster Oven Toasting Knob Replacement: adım 6, 3 resimden 2. Toaster Oven Toasting Knob Replacement: adım 6, 3 resimden 3.
    • The knob is missing in the first picture.
    • Push the knob into the hole.
    • The knob is now back in place in the last picture.
Sonuç
Alissa Mell
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 2,006
