Ana içeriğe geç
Toaster magnetic switch repair
Neye ihtiyacın var
  1. Toaster magnetic switch repair, Magnetic Switch: adım 1, 2 resimden 1. Toaster magnetic switch repair, Magnetic Switch: adım 1, 2 resimden 2.
    • Remove five screws, but the screws at the top left and right are special screws. I was able to loosen them with needle-nosed pliers and some fumbling and replaced them with Phillips screws
    • The second picture shows the very repair-unfriendly screw. Thank you Phillips!
  2. Toaster magnetic switch repair, Detach side panel and cover: adım 2, 2 resimden 1. Toaster magnetic switch repair, Detach side panel and cover: adım 2, 2 resimden 2.
    • The side wall can now be opened and removed together with the cover.
    • Do this carefully. I broke the cover
    • The control electronics are housed on the side wall and attached to the magnetic switch with a plug connection. The plug connection has to be loosened (in my case it almost came off by itself)
  3. Toaster magnetic switch repair, Remove magnetic switch: adım 3, 2 resimden 1. Toaster magnetic switch repair, Remove magnetic switch: adım 3, 2 resimden 2.
    • The arrow points to the plug connection to the control electronics. When assembling, reattach accordingly
    • The magnetic switch is held in place by a clamp that is bolted to the bottom of the toaster (see second image).
    • I had toast crumbs between the magnets and the anchor, which prevented them from working properly. I removed/scraped off these crumbs.
    • Then reassemble in reverse order.
Sonuç
Follow the steps in reverse order to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Ingmar
136 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 91
Her zaman: 3,079
