Ana içeriğe geç
Toastmaster TMHP2 Disassembly
Neye ihtiyacın var
  1. Toastmaster TMHP2 Disassembly, Toastmaster TMHP2 Disassembly: adım 1, 1 resimden 1.
    • Remove the lid and flip the pot over.
    FixBot'a Sor
    Yorum Ekle
  2. Toastmaster TMHP2 Disassembly: adım 2, 2 resimden 1. Toastmaster TMHP2 Disassembly: adım 2, 2 resimden 2.
    • Use the plastic opening tool to remove the three rubber feet.
    FixBot'a Sor
    Yorum Ekle
  3. Toastmaster TMHP2 Disassembly: adım 3, 2 resimden 1. Toastmaster TMHP2 Disassembly: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the three 11 mm screws from the bottom of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Toastmaster TMHP2 Disassembly: adım 4, 2 resimden 1. Toastmaster TMHP2 Disassembly: adım 4, 2 resimden 2.
    • Lift up the bottom cover to expose the internal wiring and components.
    FixBot'a Sor
    Yorum Ekle
  5. Toastmaster TMHP2 Disassembly: adım 5, 3 resimden 1. Toastmaster TMHP2 Disassembly: adım 5, 3 resimden 2. Toastmaster TMHP2 Disassembly: adım 5, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the two 8 mm screws securing the thermal switch.
    • Remove the bracket securing the thermal switch from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Toastmaster TMHP2 Disassembly: adım 6, 3 resimden 1. Toastmaster TMHP2 Disassembly: adım 6, 3 resimden 2. Toastmaster TMHP2 Disassembly: adım 6, 3 resimden 3.
    • Congratulations! You have disassembled the hot pot and can now see its internal compnents.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 495
