Ana içeriğe geç
Tofu65 Keyboard PCB Replacement
Neye ihtiyacın var
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: adım 1, 1 resimden 1.
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: adım 2, 1 resimden 1.
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: adım 3, 1 resimden 1.
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: adım 4, 2 resimden 1. Tofu65 Keyboard PCB Replacement: adım 4, 2 resimden 2.
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: adım 5, 2 resimden 1. Tofu65 Keyboard PCB Replacement: adım 5, 2 resimden 2.
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: adım 6, 3 resimden 1. Tofu65 Keyboard PCB Replacement: adım 6, 3 resimden 2. Tofu65 Keyboard PCB Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: adım 7, 2 resimden 1. Tofu65 Keyboard PCB Replacement: adım 7, 2 resimden 2.
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: adım 8, 2 resimden 1. Tofu65 Keyboard PCB Replacement: adım 8, 2 resimden 2.
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: adım 9, 3 resimden 1. Tofu65 Keyboard PCB Replacement: adım 9, 3 resimden 2. Tofu65 Keyboard PCB Replacement: adım 9, 3 resimden 3.
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: adım 10, 2 resimden 1. Tofu65 Keyboard PCB Replacement: adım 10, 2 resimden 2.
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Daniel Payan
202 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 57
Her zaman: 790
