Ana içeriğe geç
Toguard C200 Battery Replacement
Neye ihtiyacın var
  1. Toguard C200 Battery Replacement, Battery: adım 1, 2 resimden 1. Toguard C200 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a suction handle to remove the screen from the camera.
  2. Toguard C200 Battery Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry off the bezel.
  3. Toguard C200 Battery Replacement: adım 3, 1 resimden 1.
    • Use a Phillips screwdriver to unscrew the 4 screws to access the battery underneath.
    • Lift the motherboard slightly.
    • Make sure to keep all the screws together to not misplace any of them.
  4. Toguard C200 Battery Replacement: adım 4, 2 resimden 1. Toguard C200 Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers and your hands to remove the battery from its original place.
  5. Toguard C200 Battery Replacement: adım 5, 1 resimden 1.
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery
    • Desolder the old battery.
    • Heat the solder by using the soldering iron until it starts to melt. Try nudging the pins with the soldering iron to move the solder away from the joints. Pull the components you want to remove with the pliers.
    • Solder the new battery and make sure the + and - wires correctly match the motherboard. (Any super capacitor of 200mAh or higher will work)
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hema T
295 İtibar
1 Kılavuz yazıldı
Bir Yorum
GENIAL! muchas gracias
mfsilvam - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 130
