Ana içeriğe geç
Toilet Fill Valve Replacement
Neye ihtiyacın var
  1. Toilet Fill Valve Replacement, Tank Lid: adım 1, 3 resimden 1. Toilet Fill Valve Replacement, Tank Lid: adım 1, 3 resimden 2. Toilet Fill Valve Replacement, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
    FixBot'a Sor
    Yorum Ekle
  2. Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Toilet Fill Valve Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
    FixBot'a Sor
    Yorum Ekle
  3. Toilet Fill Valve Replacement, Refill Tube: adım 3, 3 resimden 1. Toilet Fill Valve Replacement, Refill Tube: adım 3, 3 resimden 2. Toilet Fill Valve Replacement, Refill Tube: adım 3, 3 resimden 3.
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
    FixBot'a Sor
    Yorum Ekle
  4. Toilet Fill Valve Replacement, Draining a Toilet Tank: adım 4, 2 resimden 1. Toilet Fill Valve Replacement, Draining a Toilet Tank: adım 4, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
    FixBot'a Sor
    Yorum Ekle
  5. Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: adım 5, 3 resimden 1. Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: adım 5, 3 resimden 2. Toilet Fill Valve Replacement, Sponge Drying a Toilet Tank: adım 5, 3 resimden 3.
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    FixBot'a Sor
    Yorum Ekle
  6. Toilet Fill Valve Replacement, Supply Tube: adım 6, 3 resimden 1. Toilet Fill Valve Replacement, Supply Tube: adım 6, 3 resimden 2. Toilet Fill Valve Replacement, Supply Tube: adım 6, 3 resimden 3.
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
    FixBot'a Sor
    Yorum Ekle
  7. Toilet Fill Valve Replacement, Fill Valve: adım 7, 2 resimden 1. Toilet Fill Valve Replacement, Fill Valve: adım 7, 2 resimden 2.
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
    FixBot'a Sor
    Yorum Ekle
  8. Toilet Fill Valve Replacement: adım 8, 3 resimden 1. Toilet Fill Valve Replacement: adım 8, 3 resimden 2. Toilet Fill Valve Replacement: adım 8, 3 resimden 3.
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
    FixBot'a Sor
    Yorum Ekle
  9. Toilet Fill Valve Replacement: adım 9, 2 resimden 1. Toilet Fill Valve Replacement: adım 9, 2 resimden 2.
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
    FixBot'a Sor
    Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
107.079 İtibar
270 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.842 adet Kılavuz yazıldı
5Kılavuz Yorumları
Great guide for removing the fill valve, but we're missing the steps for installing the new one. In the case of a Fluidmaster fill valve, you'll want to adjust the height to either match the one being replaced, or the more time-consuming (but not hard) method of marking the fill line of water on the tank, adjusting the fill valve to be just above that, then testing. Or ... is that another guide? For the present, I'd call this "removal." Perhaps we can create a new one for "installing a new fill valve." Ping me for assistance if needed.
David Spalding - Yanıt Paylaş
Hi David,
Thanks for checking out our guide! By default, all iFixit replacement guides conclude with "To reassemble your device, follow these instructions in reverse order." Our guide is intended to be a basic procedure that works for most fill valves. This particular fill valve is a Fluidmaster, and we do have an adjustment guide currently in the works. We'll also be updating our existing toilet guides, so make sure to check back soon.
We hope this clears everything up!
Kristen Gismondi - Yanıt Paylaş
Fluidmaster fill valve frequently fails to cut off, runs for awhile into overflow, THEN cuts off. Won’t cut off when manually toggled either. Water is hard, so could be lime deposit somewhere inside of valve. When water is turned off and tank drained for a couple of days, valve works for a few days. Any information appreciated.
Just Me - Yanıt Paylaş
ওই লেখাটা বাংলা কর
Murad Mia - Yanıt Paylaş
ইংলিশ লেখাটা সেটা বাংলা কর
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 52
Son 30 gün: 988
Her zaman: 16,321
