Ana içeriğe geç
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 1. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 2. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
    FixBot'a Sor
    Yorum Ekle
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
    FixBot'a Sor
    Yorum Ekle
  3. Toilet Flapper Replacement, Draining a Toilet Tank: adım 3, 2 resimden 1. Toilet Flapper Replacement, Draining a Toilet Tank: adım 3, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
    FixBot'a Sor
    Yorum Ekle
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 1. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 2. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 3.
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
    FixBot'a Sor
    Yorum Ekle
  5. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 1. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 2. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 3.
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
107.085 İtibar
270 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.845 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you I needed that
My Mama - Yanıt Paylaş
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 82
Son 30 gün: 356
Her zaman: 18,390
