Ana içeriğe geç
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 1. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 2. Toilet Flapper Replacement, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: adım 3, 2 resimden 1. Toilet Flapper Replacement, Draining a Toilet Tank: adım 3, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 1. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 2. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: adım 4, 3 resimden 3.
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 1. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 2. Toilet Flapper Replacement, Flapper: adım 5, 3 resimden 3.
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kristen Gismondi
105.521 İtibar
266 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
25.536 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you I needed that
My Mama - Yanıt Paylaş
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 70
Son 30 gün: 303
Her zaman: 17,981
