Ana içeriğe geç
Toilet Seat Replacement
Neye ihtiyacın var
  1. Toilet Seat Replacement, Toilet Seat: adım 1, 1 resimden 1.
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: adım 2, 2 resimden 1. Toilet Seat Replacement: adım 2, 2 resimden 2.
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: adım 3, 3 resimden 1. Toilet Seat Replacement: adım 3, 3 resimden 2. Toilet Seat Replacement: adım 3, 3 resimden 3.
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: adım 4, 2 resimden 1. Toilet Seat Replacement: adım 4, 2 resimden 2.
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: adım 5, 1 resimden 1.
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: adım 6, 1 resimden 1.
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
Sonuç
To re-install your previous seat, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Christopher Carter
231 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G5
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 2,162
