Ana içeriğe geç
Toilet Tank Assembly Replacement
Neye ihtiyacın var
  1. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 1. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 2. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
    FixBot'a Sor
    Yorum Ekle
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
    FixBot'a Sor
    Yorum Ekle
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: adım 3, 2 resimden 1. Toilet Tank Assembly Replacement, Draining a Toilet Tank: adım 3, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
    FixBot'a Sor
    Yorum Ekle
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 1. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 2. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 3.
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    FixBot'a Sor
    Yorum Ekle
  5. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 1. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 2. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 3.
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
    FixBot'a Sor
    Yorum Ekle
  6. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 1. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 2. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 3.
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
    FixBot'a Sor
    Yorum Ekle
  7. Toilet Tank Assembly Replacement: adım 7, 2 resimden 1. Toilet Tank Assembly Replacement: adım 7, 2 resimden 2.
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Ron Davis
33.479 İtibar
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Yanıt Paylaş
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Yanıt Paylaş
Thank you for the info.
DonnaRHellman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 49
Son 30 gün: 225
Her zaman: 18,331
