Ana içeriğe geç
Giriş
Use this guide to replace the entire tank assembly on a gravity flush toilet. Removing the entire tank assembly is a helpful step when moving a toilet or replacing the toilet bowl.
Parçalar
Hiçbir parça belirtilmedi.
  1. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 1. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 2. Toilet Tank Assembly Replacement, Tank Lid: adım 1, 3 resimden 3.
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 1. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: adım 2, 2 resimden 2.
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: adım 3, 2 resimden 1. Toilet Tank Assembly Replacement, Draining a Toilet Tank: adım 3, 2 resimden 2.
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 1. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 2. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: adım 4, 3 resimden 3.
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
    This is kind of funny but it worked. I had absolutely no sponges at the house, but had leftover diapers our granddaughter outgrew. I thought outside the box and ended up being impressed with the outcome. I opened up the diapers and placed in the remaining tank water. Viola, it immediately began absorbing the water. I used 4 diapers and it did the trick. Just have a leak proof trash bag on hand. No sponge, no bucket, no mess!
    Jody Broussard - Yanıt
  5. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 1. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 2. Toilet Tank Assembly Replacement, Supply Tube: adım 5, 3 resimden 3.
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  6. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 1. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 2. Toilet Tank Assembly Replacement, Tank Assembly: adım 6, 3 resimden 3.
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  7. Toilet Tank Assembly Replacement: adım 7, 2 resimden 1. Toilet Tank Assembly Replacement: adım 7, 2 resimden 2.
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
    The toilet tank can become cracked if not handled carefully.
    bridgettt - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Ron Davis
29.352 İtibar
13 adet Kılavuz yazıldı
3 Comments
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Yanıt
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Yanıt
Thank you for the info.
DonnaRHellman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 75
Son 30 gün: 360
Her zaman: 7,958
