Ana içeriğe geç
Toloco EM26 Small Motherboard Replacement
Neye ihtiyacın var
  1. Toloco EM26 Small Motherboard Replacement, Small Motherboard: adım 1, 2 resimden 1. Toloco EM26 Small Motherboard Replacement, Small Motherboard: adım 1, 2 resimden 2.
    • Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
  2. Toloco EM26 Small Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
  3. Toloco EM26 Small Motherboard Replacement: adım 3, 2 resimden 1. Toloco EM26 Small Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
  4. Toloco EM26 Small Motherboard Replacement: adım 4, 1 resimden 1.
    • Take off the cap of the massage gun by simply lifting it off the device.
    • Be careful to secure the cap as the back part of the gun may fall.
  5. Toloco EM26 Small Motherboard Replacement: adım 5, 2 resimden 1. Toloco EM26 Small Motherboard Replacement: adım 5, 2 resimden 2.
    • Unplug the cable with the small plug from the small motherboard.
  6. Toloco EM26 Small Motherboard Replacement: adım 6, 2 resimden 1. Toloco EM26 Small Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the small motherboard for replacement.
Sonuç
Zachary Olsen
536 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 38
Her zaman: 703
