Ana içeriğe geç
TomTom GO 500 Motherboard Replacement
Neye ihtiyacın var
  1. TomTom GO 500 Motherboard Replacement, TomTom GO 500 Opening the Device: adım 1, 1 resimden 1.
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. TomTom GO 500 Motherboard Replacement: adım 2, 2 resimden 1. TomTom GO 500 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
    FixBot'a Sor
    Yorum Ekle
  3. TomTom GO 500 Motherboard Replacement: adım 3, 1 resimden 1.
    • With the screen casing unlatched, locate the right side where the two connectors are.
    FixBot'a Sor
    Yorum Ekle
  4. TomTom GO 500 Motherboard Replacement: adım 4, 3 resimden 1. TomTom GO 500 Motherboard Replacement: adım 4, 3 resimden 2. TomTom GO 500 Motherboard Replacement: adım 4, 3 resimden 3.
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
    FixBot'a Sor
    Yorum Ekle
  5. TomTom GO 500 Motherboard Replacement: adım 5, 2 resimden 1. TomTom GO 500 Motherboard Replacement: adım 5, 2 resimden 2.
    • Separate the screen casing from the motherboard casing.
    FixBot'a Sor
    Yorum Ekle
  6. TomTom GO 500 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. TomTom GO 500 Motherboard Replacement: adım 7, 2 resimden 1. TomTom GO 500 Motherboard Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unplug the connector shown near the center of the motherboard using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. TomTom GO 500 Motherboard Replacement: adım 8, 2 resimden 1. TomTom GO 500 Motherboard Replacement: adım 8, 2 resimden 2.
    • Unplug the second connector using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. TomTom GO 500 Motherboard Replacement: adım 9, 2 resimden 1. TomTom GO 500 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the motherboard from the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
jkl
522 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-5, Oliver Fall 2016 UC Davis, Team 2-5, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G5
5 Üyeler
9 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hallo, wer repariert ein TomTom GO 5200? Ich habe den Akku erneuert und dabei ist der Verriegelungsstecker von der Platine zum Display (Folienstecker mit vielen Leiterbahnen) abgebrochen, sodass die Folie nicht mehr richtig eingespannt ist und das Display am Ende weiß bleibt oder mit bunten Strichen versehen ist. Wer repariert so was und was würde es kosten?
Gruß,
Reinhold
RENALDOAGG - Yanıt Paylaş
Hallo
Wo kann man für Tomtom Go500 Hauptplatine bestellen?
Pitbul77 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 2,549
