Ana içeriğe geç
TomTom GO Live 1535M Speaker Replacement
Neye ihtiyacın var
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: adım 1, 1 resimden 1.
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: adım 2, 2 resimden 1. TomTom GO Live 1535M Speaker Replacement: adım 2, 2 resimden 2.
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Simply lift the speaker up and out of the base to replace it.
Sonuç
Mathias Sagide
618 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-4, Blackwell Spring 2014 USF Tampa, Team 19-4, Blackwell Spring 2014 üyesi
USFT-BLACKWELL-S14S19G4
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 263
