Ana içeriğe geç
TomTom Go 60 S Motherboard Replacement
Neye ihtiyacın var
  1. TomTom Go 60 S Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device
  3. TomTom Go 60 S Motherboard Replacement: adım 3, 1 resimden 1.
    • Once the two covers are separated, use your fingers, to gently disconnect the wires that are connected to the motherboard from the back cover.
  4. TomTom Go 60 S Motherboard Replacement: adım 4, 1 resimden 1.
    • Next, you must remove the motherboard from the front screen.
    • Use a Phillips #000 screwdriver to unscrew the screws.
  5. TomTom Go 60 S Motherboard Replacement: adım 5, 2 resimden 1. TomTom Go 60 S Motherboard Replacement: adım 5, 2 resimden 2.
    • Separate the motherboard from the front cover, you must disconnect the wires connecting the two.
  6. TomTom Go 60 S Motherboard Replacement: adım 6, 1 resimden 1.
    • The motherboard is now disconnected from the front assembly
Sonuç
Ambermarie Dawdy
74 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Nance Fall 2016 USF Tampa, Team 1-6, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G6
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
What is the purpose of single yellow wire ?
is it ok if it is disconnected ? I fear to have unsoldered it or is it just an alone wire ?
Thanks
ugo ceruti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,257
