Ana içeriğe geç
TomTom Go Blue and Me Disassembly
Neye ihtiyacın var
  1. TomTom Go Blue and Me Disassembly, Remove the bezels: adım 1, 2 resimden 1. TomTom Go Blue and Me Disassembly, Remove the bezels: adım 1, 2 resimden 2.
    • Use a flat head screwdriver or plastic spatula to remove the bezels from the side of the screen.
    • Now the torx screws are visible
  2. TomTom Go Blue and Me Disassembly, Disconnect screen from mainboard: adım 2, 2 resimden 1. TomTom Go Blue and Me Disassembly, Disconnect screen from mainboard: adım 2, 2 resimden 2.
    • When the screws are out, the screen is separated from the back of the housing.
    • the screen is still connected with a flat cable and a power cable
    • The power cable should be pulled first
    • The flat cable can be disconnected by lifting up the black part of the connector.
  3. TomTom Go Blue and Me Disassembly, Disconnect battery and loudspeaker: adım 3, 2 resimden 1. TomTom Go Blue and Me Disassembly, Disconnect battery and loudspeaker: adım 3, 2 resimden 2.
    • Next, the main board should be disconnected from the battery
    • and from the loud speaker
  4. TomTom Go Blue and Me Disassembly, Battery and loudspeaker: adım 4, 2 resimden 1. TomTom Go Blue and Me Disassembly, Battery and loudspeaker: adım 4, 2 resimden 2.
    • You can now unscrew the mainboard
  5. TomTom Go Blue and Me Disassembly, access to battery and loudspeaker: adım 5, 1 resimden 1.
    • When you now lift out the mainboard, you have access to the battery and loudspeaker.
    • The battery is glued in. you need to heat it up to get it out.
  6. TomTom Go Blue and Me Disassembly, On/Off button: adım 6, 2 resimden 1. TomTom Go Blue and Me Disassembly, On/Off button: adım 6, 2 resimden 2.
    • This little piece of plastic was my reason for opening it up. The longer leg was broken. I glued it with superglue and put it back. so far this seams feasible
    • Please note the broken bits in the holes at the end of the legs: you can not actually take this out without breaking it! so be ware!
Sonuç
Bir başkası bu kılavuzu tamamladı.
hjheins
259 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,278
