Ana içeriğe geç
TomTom ONE Battery Replacement
Neye ihtiyacın var
  1. TomTom ONE Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Battery Replacement: adım 2, 2 resimden 1. TomTom ONE Battery Replacement: adım 2, 2 resimden 2.
    • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Battery Replacement: adım 3, 1 resimden 1.
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Battery Replacement: adım 5, 2 resimden 1. TomTom ONE Battery Replacement: adım 5, 2 resimden 2.
    • Using the spudger, gently pry out the battery.
    • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Trevor Foster
148 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G7
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 11,028
