Ana içeriğe geç
TomTom ONE Screen Replacement
Neye ihtiyacın var
  1. TomTom ONE Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: adım 2, 2 resimden 1. TomTom ONE Screen Replacement: adım 2, 2 resimden 2.
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: adım 3, 1 resimden 1.
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: adım 5, 1 resimden 1.
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: adım 6, 2 resimden 1. TomTom ONE Screen Replacement: adım 6, 2 resimden 2.
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: adım 7, 1 resimden 1.
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: adım 8, 2 resimden 1. TomTom ONE Screen Replacement: adım 8, 2 resimden 2.
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Alex Cauvy
41 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G7
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 9,987
