Ana içeriğe geç
Giriş
This guide will teach you how to replace the battery of the TOMTOM XL if the battery is dead or malfunctioning.
Parçalar
Hiçbir parça belirtilmedi.
  1. TomTom One XL Battery Replacement, Back Panel: adım 1, 2 resimden 1. TomTom One XL Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: adım 2, 1 resimden 1.
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: adım 3, 1 resimden 1.
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: adım 4, 2 resimden 1. TomTom One XL Battery Replacement: adım 4, 2 resimden 2.
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: adım 6, 3 resimden 1. TomTom One XL Battery Replacement: adım 6, 3 resimden 2. TomTom One XL Battery Replacement: adım 6, 3 resimden 3.
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: adım 7, 3 resimden 1. TomTom One XL Battery Replacement: adım 7, 3 resimden 2. TomTom One XL Battery Replacement: adım 7, 3 resimden 3.
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: adım 8, 3 resimden 1. TomTom One XL Battery Replacement: adım 8, 3 resimden 2. TomTom One XL Battery Replacement: adım 8, 3 resimden 3.
    • Reconnect the battery ribbon cable to its port.
Sonuç
DeVhan
401 İtibar
4 adet Kılavuz yazıldı
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,303
