Ana içeriğe geç
TomTom One XL Charging Port Replacement
Neye ihtiyacın var
  1. TomTom One XL Charging Port Replacement, Back Panel: adım 1, 2 resimden 1. TomTom One XL Charging Port Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Charging Port Replacement: adım 2, 1 resimden 1.
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Charging Port Replacement: adım 3, 1 resimden 1.
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Charging Port Replacement: adım 4, 2 resimden 1. TomTom One XL Charging Port Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Charging Port Replacement, Charging Port: adım 5, 2 resimden 1. TomTom One XL Charging Port Replacement, Charging Port: adım 5, 2 resimden 2.
    • If this is your first time solder then refer to IFixIt's safety guide.
    • Locate where the charger port goes on the circuit board.
    • Locate the four connecter on circuit board and charger port which need to be soldered.
    • Don't forget, the soldering iron is hot.
  6. TomTom One XL Charging Port Replacement: adım 6, 3 resimden 1. TomTom One XL Charging Port Replacement: adım 6, 3 resimden 2. TomTom One XL Charging Port Replacement: adım 6, 3 resimden 3.
    • Using your plastic opening tool press down firmly on the top of the charger port.
    • While the soldering iron is hot press it again the four corners of the charger port.
    • Don't touch the charger port with your hands, it may have heated up during soldering.
  7. TomTom One XL Charging Port Replacement: adım 7, 3 resimden 1. TomTom One XL Charging Port Replacement: adım 7, 3 resimden 2. TomTom One XL Charging Port Replacement: adım 7, 3 resimden 3.
    • Let the circuit board and charger port cool down for a few minutes.
    • Lift circuit board up, after making sure its cool, to see if four corners are all connected.
    • Plug in the charger to make sure it works, if not repeat steps and make sure the port is making a clean connection.
Sonuç
DeVhan
401 İtibar
4 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 2,424
