Ana içeriğe geç
TomTom One XL Power Button Replacement
Neye ihtiyacın var
  1. TomTom One XL Power Button Replacement, Back Panel: adım 1, 2 resimden 1. TomTom One XL Power Button Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the 4 .4mm screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. TomTom One XL Power Button Replacement: adım 2, 1 resimden 1.
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    FixBot'a Sor
    Yorum Ekle
  3. TomTom One XL Power Button Replacement: adım 3, 1 resimden 1.
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    FixBot'a Sor
    Yorum Ekle
  4. TomTom One XL Power Button Replacement: adım 4, 2 resimden 1. TomTom One XL Power Button Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    FixBot'a Sor
    Yorum Ekle
  5. TomTom One XL Power Button Replacement, Power Button: adım 5, 1 resimden 1.
    • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
    • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
    FixBot'a Sor
    Yorum Ekle
  6. TomTom One XL Power Button Replacement: adım 6, 2 resimden 1. TomTom One XL Power Button Replacement: adım 6, 2 resimden 2.
    • Detach the ribbon wire from it's port on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. TomTom One XL Power Button Replacement: adım 7, 3 resimden 1. TomTom One XL Power Button Replacement: adım 7, 3 resimden 2. TomTom One XL Power Button Replacement: adım 7, 3 resimden 3.
    • Now the power button is exposed and any obstructions can be easily removed.
    • If you want to replace the button it can easily be popped out using your hands.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jesse
101 İtibar
1 Kılavuz yazıldı
Ekip
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S9G6
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 2,582
