Ana içeriğe geç
TomTom One XL Screen Replacement
Neye ihtiyacın var
  1. TomTom One XL Screen Replacement, Back Panel: adım 1, 2 resimden 1. TomTom One XL Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the 4 .4mm screws on the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. TomTom One XL Screen Replacement: adım 2, 1 resimden 1.
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
    FixBot'a Sor
    Yorum Ekle
  3. TomTom One XL Screen Replacement: adım 3, 1 resimden 1.
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
    FixBot'a Sor
    Yorum Ekle
  4. TomTom One XL Screen Replacement: adım 4, 2 resimden 1. TomTom One XL Screen Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
    FixBot'a Sor
    Yorum Ekle
  5. TomTom One XL Screen Replacement, Screen: adım 5, 2 resimden 1. TomTom One XL Screen Replacement, Screen: adım 5, 2 resimden 2.
    • Locate the 4 .4mm screws connecting the circuit board to the front panel.
    • Use the T6 Torx screwdriver and remove the four screws.
    FixBot'a Sor
    Yorum Ekle
  6. TomTom One XL Screen Replacement: adım 6, 3 resimden 1. TomTom One XL Screen Replacement: adım 6, 3 resimden 2. TomTom One XL Screen Replacement: adım 6, 3 resimden 3.
    • Locate the ribbon cable connecting the front panel to the circuit board.
    • Locate the white tab locking the ribbon in place.
    • Using precision tweezers push the left and right side of the tab forward.
    • Gently pull the ribbon to disconnect the circuit board from the front panel.
    • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
    FixBot'a Sor
    Yorum Ekle
  7. TomTom One XL Screen Replacement: adım 7, 3 resimden 1. TomTom One XL Screen Replacement: adım 7, 3 resimden 2. TomTom One XL Screen Replacement: adım 7, 3 resimden 3.
    • Use the palate knife to pry the screen away from the front panel.
    • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
    • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
DeVhan
401 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 1,239
