Ana içeriğe geç
TomTom Runner GPS Component Replacement
Neye ihtiyacın var
  1. TomTom Runner GPS Component Replacement, Wristband: adım 1, 1 resimden 1.
    • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
    FixBot'a Sor
    Yorum Ekle
  2. TomTom Runner GPS Component Replacement: adım 2, 2 resimden 1. TomTom Runner GPS Component Replacement: adım 2, 2 resimden 2.
    • Continue to lift up on the band until the screen of the watch becomes loose from the band.
    • You may need to apply a small amount of force downward on the face of the screen.
    • Continue to pull up on the wristband until it is completely off the watch.
    FixBot'a Sor
    Yorum Ekle
  3. TomTom Runner GPS Component Replacement, Back Panel: adım 3, 1 resimden 1.
    • Grab the watch once it is separated from the wristband.
    FixBot'a Sor
    Yorum Ekle
  4. TomTom Runner GPS Component Replacement: adım 4, 1 resimden 1.
    • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. TomTom Runner GPS Component Replacement: adım 5, 2 resimden 1. TomTom Runner GPS Component Replacement: adım 5, 2 resimden 2.
    • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
    • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
    • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
    FixBot'a Sor
    Yorum Ekle
  6. TomTom Runner GPS Component Replacement: adım 6, 2 resimden 1. TomTom Runner GPS Component Replacement: adım 6, 2 resimden 2.
    • Gently pull the back panel away from the front panel.
    • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
    FixBot'a Sor
    Yorum Ekle
  7. TomTom Runner GPS Component Replacement: adım 7, 2 resimden 1. TomTom Runner GPS Component Replacement: adım 7, 2 resimden 2.
    • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
    • Be gentle with the red and black wires. You do not want them to rip or pop out.
    • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
    FixBot'a Sor
    Yorum Ekle
  8. TomTom Runner GPS Component Replacement, GPS Component: adım 8, 2 resimden 1. TomTom Runner GPS Component Replacement, GPS Component: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Now lift the smaller square of copper off the front panel. Use the precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
    • You will need to be gentle and pull the copper slowly so that it does not rip.
    FixBot'a Sor
    Yorum Ekle
  9. TomTom Runner GPS Component Replacement: adım 9, 3 resimden 1. TomTom Runner GPS Component Replacement: adım 9, 3 resimden 2. TomTom Runner GPS Component Replacement: adım 9, 3 resimden 3.
    • Use your fingers to gently grab and lift the small square piece to remove the GPS and button component competely from the casing.
    • Disconnect the ZIF Connector from the larger green motherboard.
    • The ZIF Connector is the flat, orange cable connecting the small green motherboard to the larger motherboard. It is meant to come apart at the port located on the larger motherboard. You will feel like you have broken it when it is disconnected. That is okay!
    FixBot'a Sor
    Yorum Ekle
  10. TomTom Runner GPS Component Replacement: adım 10, 3 resimden 1. TomTom Runner GPS Component Replacement: adım 10, 3 resimden 2. TomTom Runner GPS Component Replacement: adım 10, 3 resimden 3.
    • Get the GPS/Button Component by itself and use the Spudger tool to lift the silver cover off the GPS Component. This will expose the GPS Component.
    FixBot'a Sor
    Yorum Ekle
  11. TomTom Runner GPS Component Replacement: adım 11, 2 resimden 1. TomTom Runner GPS Component Replacement: adım 11, 2 resimden 2.
    • Once the GPS Component cover is off and the GPS Component is exposed, you are ready to replace it.
    • The GPS Component is the entire square, grey box piece with the green motherboard attached to it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Amber Scarborough
1.157 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G6, Bennett Spring 2017 Texas Tech, Team S8-G6, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G6
4 Üyeler
15 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do i buy the GPS component for replacement?
tolstih.kirill - Yanıt Paylaş
Hi,
Thanx so much for this guide. Now I’m looking for a new GPS component.Do you know where I can buy that?
Regards, Rein Kooijman (the Netherlands)
Rein Kooijman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 2,140
