Ana içeriğe geç
TomTom VIA 1530 TM Back Replacement
Neye ihtiyacın var
  1. TomTom VIA 1530 TM Back Replacement, Back: adım 1, 2 resimden 1. TomTom VIA 1530 TM Back Replacement, Back: adım 1, 2 resimden 2.
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
    FixBot'a Sor
    Yorum Ekle
  2. TomTom VIA 1530 TM Back Replacement: adım 2, 2 resimden 1. TomTom VIA 1530 TM Back Replacement: adım 2, 2 resimden 2.
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. TomTom VIA 1530 TM Back Replacement: adım 3, 2 resimden 1. TomTom VIA 1530 TM Back Replacement: adım 3, 2 resimden 2.
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
    FixBot'a Sor
    Yorum Ekle
  4. TomTom VIA 1530 TM Back Replacement: adım 4, 2 resimden 1. TomTom VIA 1530 TM Back Replacement: adım 4, 2 resimden 2.
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
    FixBot'a Sor
    Yorum Ekle
  5. TomTom VIA 1530 TM Back Replacement: adım 5, 3 resimden 1. TomTom VIA 1530 TM Back Replacement: adım 5, 3 resimden 2. TomTom VIA 1530 TM Back Replacement: adım 5, 3 resimden 3.
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jennifer Zakaria
555 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G2, Banghart Winter 2018 Cal Poly, Team S12-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 936
