Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The back is either connected or interfaced with most components of the device. Since this must be removed in order to reach other interior components of the device, this guide will show how to remove it properly.
Neye ihtiyacın var
Position the device so that the underside is facing up.
Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
Firmly grab the EasyPort Mount and remove it.
