Giriş
The TomTom VIA 1530 TM battery can wear out over time due to overuse or overheating and will stop working completely. This guide will show how to properly remove it.
Neye ihtiyacın var
Position the device so that the underside is facing up.
Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
Firmly grab the EasyPort Mount and remove it.
Free the battery cable from its notched position.
Use the plastic opening tool to separate the battery from the case.
