Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
The TomTom VIA 1530 TM battery can wear out over time due to overuse or overheating and will stop working completely. This guide will show how to properly remove it.
  1. Position the device so that the underside is facing up. Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Position the device so that the underside is facing up.
    • Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
    • Firmly grab the EasyPort Mount and remove it.
    • If it does not dislodge easily, gently twist the EasyPort Mount, applying increasing pressure until it does.
  2. Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top. Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
    • Turn the device 180 degrees so the screw in the EasyPort Mount compartment is on top.
    • Remove the 2mm screw beneath the EasyPort Mount compartment with the Torx T-5 head Screwdriver.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Flip the device over so that the screen is facing up. Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • Flip the device over so that the screen is facing up.
    • Wedge the plastic opening tool between the top and bottom of the device's frame, gently sliding it around the outside edge.
    • It may be easier to start at one of the corners.
    • The gold ribbon cable connecting the screen to the motherboard is fragile and tears easily.
    • This specific device's ribbon cable is torn.
  5. Carefully slide the screen forward, revealing the lower portion of the motherboard. Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Carefully slide the screen forward, revealing the lower portion of the motherboard.
    • Remove the 3.6mm screw using the JIS #00 Screwdriver.
    • Rotate the device 180 degrees, carefully slide back the screen, and remove the remaining two screws.
  6. Disconnect the battery and speaker cables. Unlatch the motherboard from the case. Unlatch the motherboard from the case.
    • Disconnect the battery and speaker cables.
    • Unlatch the motherboard from the case.
  7. Free the battery cable from its notched position. Use the plastic opening tool to separate the battery from the case. The tearing sound is the adhesive holding the battery tot he case. It will re-stick when you put the battery back in.
    • Free the battery cable from its notched position.
    • Use the plastic opening tool to separate the battery from the case.
    • The tearing sound is the adhesive holding the battery tot he case. It will re-stick when you put the battery back in.
Sonuç
Jennifer Zakaria
531 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team S12-G2, Banghart Winter 2018 Cal Poly, Team S12-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 247
