Giriş
The speaker is a crucial component of the GPS that can wear out or stop working over time. This guide will show how to properly remove it.
Neye ihtiyacın var
Position the device so that the underside is facing up.
Tilt the EasyPort Mount slightly upward and rotate it counterclockwise 180 degrees from the initial position.
Firmly grab the EasyPort Mount and remove it.
Use the pointed edge of the spudger to pop the speaker out of its compartment.
