Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The TomTom VIA 1605TM, along with all GPSs, needs a sound function for when the user can't take his/her eyes off the road to get directions. This guide will help replace that. When prying do not use metal tools as this can cause static damage. Avoid direct contact on the pad of the speaker as this could damage it. The device can be identified by its model number which is located under the small panel on the bottom of the device.
Neye ihtiyacın var
Locate the round suction cup on the back of the device.
Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard behind the LCD Screen.
Unscrew each of these in a counter clockwise direction.
Remove speaker from slot on back panel by prying out of the rubber/plastic case with the plastic opening tool. If this does not work the metal spudger is okay for this step.
Remove the existing speaker from it's connection to the motherboard by pinching both sides of the connector.
Pull back away (in the opposite direction) from the connector.
